LinkBack | Thread Tools | Rate Thread |
Anywhere that would accept early calipers as cores and send rebuilt one?
I have excellent braking but one bleeder is being picky. I have 4 core calipers from another 1966 that I would like to have rebuilt and installed. Is there anywhere that will exchange them out. I know there are a couple rebuilders but I think 4 calipers goes for like $1000?
gearhead
Have you talked to Eric Shea? It's been a while since I touched base with him, so I don't know what his current rates are. If you don't know how to contact him, drop me a line. He does fabulous work...
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Yea, that is what I was going to suggest. I know Eric does 914 calipers that way.
PMB Performance -Britain
'69 912 w/ 2.3L Type-4 Turbo Engine '74 914 1825lbs, JDM Subaru STi Spec-C Engine, Lotus Suspension, 930 Trans. '80 924 AAN 5-Cyl, Corvette C5 Transaxle - Team UBoot Rennwerks -- www.britainracing.com -- |
darnellsgarage
Have you tried http://www.classicandspeedparts.com/. I have been pretty happy with thier service.
don |
I may have to do this myself! Those prices are fair but $1,000 for caliper rebuilds is a ton of money!
I think if I strip out the calipers and remove the through bolts I can do a good clean up and rebuild. Anywhere to buy new throughbolts and stainless steel pistons? |
Capitalist and Patriot
Are these the "M" calipers?
There are paces where you could buy remand calipers and get an upgrade WAAY cheaper than 1k! You could get an upgrade and not even send in your calipers and get a big perf gain..
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Here's a link to "M" calipers for MY upto '75
http://www.***********************/search/?N=11565+1698+4294966713+6853 or for upgrade less expensive: http://www.***********************/search/?N=11565+1698+4294966694+6853 Happy hunting!
Send them to White Post Restorations. There are plenty of areas to save money but brakes ain't one of them.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
A.K.A. GOB Bluth
Doesn't Vertex do that?
Paul Misencik Huntersville, NC |
Highway robbery......I had a local brake place do the 4 on my 73.5 for $165 back in about 1994. I recently called to have them do the ones on my '69 and they don't do Porsche calipers anymore. Sad.
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
You can rebuild them yourself without too much trouble. The kits are cheap and the process fairly simple. Soak the calipers in kerosene to loosen fasteners and clean up the gunk. Once you get them apart you can inspect the cylinders, bores and caliper frames for damage and go from there; if they are damaged, don't rebuild. Otherwise just clean up the cylinder and bores with silicon carbide paper and light oil, degrease with brake cleaner and reassemble with silicon brake lube. Replace the bleeder valves and you should be good to go. Lots of threads on this process, it really is simple - each caliper has just a few parts.
Good luck!
Joe 85 Carrera 64 Honda Dream - for sale 71 Hodaka Super Rat - keeper |
Maybe here?
For what Eric does it is very good value. Those early calipers are a lot trickier than the 69 and later models. I do a lot of calipers myself, so I know what is involved.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
where can you buy the replacement steel or stainless pistons for the steel SC & Carrera calipers?
Pelican sells the rebuild kits but not the pistons. Only piston they sell is the stomski for the alloy calipers... Thanks, Bob
I live for 911 tweaks... |
Tru6 Restoration & Design |
I don't know if this is of any interst but I have a pair of freshly rebuilt front SC calipers that I bought from Pelican Syncroid here but never installed. They have all new, fresh zinc plated hardware and I'll let them go for $200 plus shipping. I don't have a picture on my home pc but can take a picture if anyone is intersted.
Dan in Pasadena '76 911S Sahara Beige/Cork |
thanks Dan for the offer... however, I am upgrading to the carrera calipers & rotors.
Take care! Bob
brakes
dan.... can you post some pictures?.... what comes in deal?
