Which side of Exh Gasket faces engine?
Got my exhaust gaskets for 911SC 3.0liter from host. One side is smooth; the other has the steel ring jutting out. Does the "ring" side face the engine, fitting in the chamfered edge, or vice versa? ALSO, has anyone used any hi temp goop to help seal the rough surface that may be present on the header flange? thanks.
Old 12-06-2007, 03:26 AM
abit off center
cgarr's Avatar
I always put the flat side of the gasket to the alum head, the head surface is more true than a header flange and let the raised ring part of the gasket seal against the steel header where the surface may not be so true.
______________________
Craig
G2Performance
Old 12-06-2007, 05:16 AM
3.2 CAB's Avatar
+1
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-06-2007, 06:59 AM
KTL KTL is offline
Schleprock
KTL's Avatar
I install the same way- ring faces exhaust flange.
no goop. the gaskets are soft so they should seal fine. If the rough surface bothers you, hit it with a scotchbrite pad or mildly stiff wire brush. Probably unneccessary unless there's really big chunks of old gasket material (or unnecessary goop )
Kevin L
'86 Carrera "Larry"
Old 12-06-2007, 10:57 AM
Thanks to all for the fast response. It's out into the 32 degree weather (even in the garage) to knock this off tonight!
Suuuurrrrrre, the weather was 65 three days ago, but the gaskets came painfully by FedEx truck (!?) -- I tracked them agonizingly through every gawd-forsaken city in the US as they progressed across, up and down and up again, from CA to VA. Never thought I would request USPS in favor of FedEx, but, in the future, orders from Pelican will be via USPS.
Old 12-06-2007, 02:04 PM
