engine wiring ?
I have a 77 CIS I am putting together and seem to have an extra female 2 wire connector. It is at L/R of motor and has 2 brn w/white rings around them in one terminal and a blue with yellow running length-wise. Cant locate it on my diagrams or PP.
Old 12-07-2007, 09:39 PM
911quest's Avatar
What color is the connector?
Tony Proasi
1969S
1957 VW Pickup
Old 12-08-2007, 06:33 AM
Extra Wirings.......
Boss,
The Blue/yellow is coming from S22 (rear fuse) and ends up at terminal #7 (14-pin connector). This is an unused line (open connector).
The Brown/white wire is coming off from terminal #2 (14-pin connector). This also an extra line and not in use.
These extra wires are not utilized in '77 (USA models) as per factory wiring diagram. HTH.
TD
Old 12-08-2007, 08:21 AM
Quest - conn. is white and has a 90 degree bend looking at the end instead of side by side terminals . It also has a black bell shaped protective boot .
Boyt - Thanks for the help ..... again . What is a good source for ACCURATE year specific diagrams .
Old 12-08-2007, 08:47 AM
For Better Feedback.......
Boss,
Take some pictures of the connector in question and you'll have more and better feedback from the readers.
For wiring diagrams: The factory manual(s) with color code wiring makes it very convenient to read and follow the diagram.
TD
Old 12-08-2007, 09:20 AM
Photos
These may help.
Old 12-08-2007, 06:10 PM
photos
Old 12-08-2007, 06:22 PM
that plug may be to hook up a Euro rear fog light ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-09-2007, 04:12 AM
Plug
Hi, I think that was the electrical connection for the vacuum valve on the sportomatic system.
Old 12-09-2007, 04:31 AM
