Valve adjustment tool
Does anyone have any experience with either one of these tools:
Seems they would make the process easier... One is a Schley ![]() Not sure who makes this one, but it seems like it gives you more room: ![]()
Current Drivers - 2006 BMW 1 Series & MB E320 Wagon (new addition 1998 Mazda Roadster) EX - 1993 Porsche 911 Carrera 2 EX - 1979 Porsche 911SC TARGA EX - 1976 BMW 2002 |
tried all that stuff eons ago. clumsy basically. you get used to the regular way soon enough.
I haven't used either but I have where some swear by the first one pictured. I just use the ptool and the backside method to check things.
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche |
I like to use an offset screwdriver.
87 Carerra Coupe 04 GMC Yukon 07 Mazda 3 00 GMC Sierra |
Bird. It's the word...
John' right.
John Forcier Current: 68L 2.0 Hotrod - build underway |
I've used the one on top. If you're used to it, it's sweet, but way different than a screwdriver and wrench. It's a totally different feel, and probably awkward if you're used to the conventional method. Works best when the motor is on a stand.
Jon |
Why is it I chuckle every time I hear the "infamous" backside method mentioned? I've not tried it, but I don't see the need to. The regular method is pretty straight forward and accurate. I really don't see why people make a big deal of it?
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Agree 100%. Also, why do some have a problem with figuring out what a "light drag" on the feeler gauge is? Didn't they grow up adjusted valves on their 1952 Chevy or own motorcycles in their life?????
Bob S. 73.5 911T 1969 911T Coo' pay (one owner) 1960 Mercedes 190SL 1962 XKE Roadster (sold) - 13 motorcycles |
Dude,
I have a phd in Computer science. I didn't know how to change oil before I got this car. My lack of an automotive background makes me a bit unsure of things. But either way I like things to be precise. You can't just "feel" electronics are working or a program is going to work. Granted thus far my feel has been dead on but I want to know my adjustment is exact and the backside method assures just that. The next time you have an engine rebuild just tell your machinist to feel if all of his machine work is correct. Who needs measurements with these cars ![]()
Tom Hutchinson 80 Targa / 81 Coupe / 71 Targa (in Porsche heaven) My Garage Build: https://youtu.be/H0n_NwEQVbs "If one does not fail at times, then one has not challenged himself." Ferdinand Porsche Last edited by khamul02; 02-03-2008 at 05:55 AM.. |
I agree with JWW... the basic flathead and wrench are the best way to go... you'll get use to it.
The sliding drag on a feeler gauge is very similar to the drag on a micrometer or a vernier necessary for the correct measurement - and for the same reason. There's no extra clearance, just the gap. Even tech weenies can do it just fine, it's only practise. I know, 'coz I is one. ![]() I worked in Mech Eng and toolshops for a few years before I went clean fingernails in the 80's - but at one time, I could eyeball a spark plug or contact breaker gap within a thou or two, certainly good enough for side of the road. The fact that one thickness of a cardboard Marlboro box was 0.012" often helped for a quick check, too...
'77 S with '78 930 power and a few other things. |
Man, I only have time to master so many things
