What do i need? Putting 3.2 in a 71
Ive done a search and I'm wanting to put a list together on some of the things I need to put a 3.2 in my 71 roller. Ive got a 84 euro motor with wiring harness and dme.
Fuel Filter Fuel Pump Newer gas tank for return fuel line return line coil external oil cooler, thermostat, lines oil tank? 915 trans, shifter, tube. Heat exchangers I want to backdate engine tin for heater backdate I know there will be alot of small misc things, Im just trying to put together some of the larger things that I hope to be able to pick up used. Am I missing anything. Do I need to change the oil tank? Suggestions. |
I used my old ('73.5) old tank - I have carbs. DME shold be ok w/ old tank.
How about the tach? is it compatible? same for speedo - mech vs. elec. depending on what trans you use. You need the newer 915 type trans. cross brace. fuel pump bracket for Front cross arm. |
When I did the 3.2 swap on my 73T I used my original fuel tank but with Carrera fuel lines. You pretty much have all the parts covered but when you start the install don't hesitate to ask for help. I'll be more than happy to walk you through it!
thanks guy's, Im mainly in the planning stage now. I was thinking that I could use the one fuel hardline thats in my tunnel now and just run another fuel line thats not their on my 71. On my 73 there is two hardlines running through the tunnel. My 73 has the CIS so I guess it is different from the 71.
I'm wondering if I still need the lines that run to the charcoal canister. If I can pull them out I'm wondering if I can replace one with a fuel line. I was looking at my 71 and the fuel pump is mounted in the front and their is two lines running to the fuel tank. I suppose I could use one of those for the return line. |
emissions laws/inspection in St. Louis?
might need to maintain exisiting or replumb like on the DME motor... |
Thanks, that will help alot ! |
It sounds like you are prepared to give up the wonderful road-racing shift pattern of your current transmission....??
From what I understand, the 901 trans wont hold up to the torque of the 3.2. I'd love to keep it just because I'm cheap and I already have one. |
I have a typ 911 trans. (like yours) on my 3.2 - it has been endless trouble b/c the guy put an incorrect conversion flywheel on it. I am not giving up yet tho ...
But it would perhaps be cheaper to use a 915 on the 3.2 - esp. w/ the DME sensors - I have carbs. |
| All times are GMT -8. The time now is 03:52 PM. |
