What do i need? Putting 3.2 in a 71
Ive done a search and I'm wanting to put a list together on some of the things I need to put a 3.2 in my 71 roller. Ive got a 84 euro motor with wiring harness and dme.
Fuel Filter
Fuel Pump
Newer gas tank for return fuel line
return line
coil
external oil cooler, thermostat, lines
oil tank?
915 trans, shifter, tube.
Heat exchangers I want to backdate
engine tin for heater backdate
I know there will be alot of small misc things, Im just trying to put together some of the larger things that I hope to be able to pick up used.
Am I missing anything. Do I need to change the oil tank? Suggestions.
2000 Boxster S (gone)
1972 911s Targa (sold)
1971 911t coupe roller (sold)
1973 911t coupe / 3.2 (sold)
Gruppe B #057
Old 12-09-2007, 10:55 AM
AutoBahned
RWebb's Avatar
I used my old ('73.5) old tank - I have carbs. DME shold be ok w/ old tank.
How about the tach? is it compatible?
same for speedo - mech vs. elec. depending on what trans you use.
You need the newer 915 type trans. cross brace.
fuel pump bracket for Front cross arm.
Old 12-09-2007, 01:50 PM
dezzmo's Avatar
When I did the 3.2 swap on my 73T I used my original fuel tank but with Carrera fuel lines. You pretty much have all the parts covered but when you start the install don't hesitate to ask for help. I'll be more than happy to walk you through it!
EarlyS 1017
RGruppe 663
73 911T 3.2
01 Ducati S4 Monster 00 Ducati 996
Old 12-09-2007, 02:19 PM
thanks guy's, Im mainly in the planning stage now. I was thinking that I could use the one fuel hardline thats in my tunnel now and just run another fuel line thats not their on my 71. On my 73 there is two hardlines running through the tunnel. My 73 has the CIS so I guess it is different from the 71.
I'm wondering if I still need the lines that run to the charcoal canister. If I can pull them out I'm wondering if I can replace one with a fuel line. I was looking at my 71 and the fuel pump is mounted in the front and their is two lines running to the fuel tank. I suppose I could use one of those for the return line.
Gruppe B #057
Old 12-09-2007, 07:33 PM
AutoBahned
RWebb's Avatar
emissions laws/inspection in St. Louis?
might need to maintain exisiting or replumb like on the DME motor...
Old 12-09-2007, 10:13 PM
Here's a great site that explains everything:
http://www.pelicanparts.com/MotorCity/marcesq1/
Old 12-10-2007, 05:34 AM
Not sure about emissions on a 71 but I can always licence it as historic. That just requires $25 and proof of insurance and paid PP tax. You are suppose to limit your driving to something like 1000 miles per year but Ive never heard of anyone being checked. I probably wouldn't put much more than that on it anyway.
Gruppe B #057
Old 12-10-2007, 06:39 AM
Thanks, that will help alot !
Gruppe B #057
Old 12-10-2007, 06:52 AM
AutoBahned
RWebb's Avatar
It sounds like you are prepared to give up the wonderful road-racing shift pattern of your current transmission....??
Old 12-10-2007, 10:37 AM
From what I understand, the 901 trans wont hold up to the torque of the 3.2. I'd love to keep it just because I'm cheap and I already have one.
Gruppe B #057
Old 12-10-2007, 12:34 PM
AutoBahned
RWebb's Avatar
I have a typ 911 trans. (like yours) on my 3.2 - it has been endless trouble b/c the guy put an incorrect conversion flywheel on it. I am not giving up yet tho ...
But it would perhaps be cheaper to use a 915 on the 3.2 - esp. w/ the DME sensors - I have carbs.
Old 12-10-2007, 12:40 PM
My '70 only had one fuel line running through the tunnel so I decided to remove it and run 2 soft lines as used in later cars. After pulling the hard line out, I tapped it on the floor and a pile of rust came out, so I'm glad I went this route. It's a pain to run these new lines through the tunnel but it paid off when all I had to do was screw one to the tank (later fuel tank as well) and the other (banjo fitting) plugged in to a carrera fuel pump. On the engine side, the hard lines that go to the fuel filter and the engine return side plugged right in to the tunnel lines. The later tunnel lines aren't cheap though... If I remember correctly they were about $100 each. My car was a shell at the time so it was a good time to upgrade and I just didn't want to deal with custom fittings or running the risk of one popping off and dumping fuel, etc.
Old 12-10-2007, 01:51 PM
