New Thread - What to do with fan blade and alternator housing (cosmetically)
I started with a voltage regulator problem thread, now I am trying to figure out before I put my fan back in and alternator housing how to clean them up. (see pic)
I am waiting on a quote to sand blast them both. I'm in Colorado. Anybody see any issues with that route? I probably wont clear coat though. thinking just sand blast them and put them back in and occasionally wipe them clean. anyone do this? whats your recommendations? I read pretty much not to paint it or powdercoat them. Dont want a high polished look, just a nice satin grey would be good.
1979 911 SC 1974 OEM 911 Exhaust and Muffler - Modified to a 2-out Fiberglas Goodies, 17" C4 Cup Wheels |
Just degrease everything and then glass-bead the fan. Follow that with a few coats of Krylon Clear and that looks very good.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Lots of people paint and powder coat these two pieces, but you can also have them cleaned up and apply something like gibbs.
72 911 Although it is done at the moment, it will never be finished. |
porsher
light sandblast and gibbs penetrant is great: nice satin grey nekkid mag finish.
gibbs prevents the surface from oxidizing so the finish doesn't degrade
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
winter
good question and thanks for starting the thread, Steve's answer has me thinking that's what I'll do to mine.
Cheers!
Tom '76 Targa |
Mo money = mo parts
PS - There are a number of threads on fans.
Greg 86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten 65 Ducati Monza 250 & 66 Monza Junior (project) "if you are lucky enough to own a Porsche, you are lucky enough" |
Okay, so found a company that will bead blast it, sd it will strip to bare metal. $60. Said they would recommend getting a clear coat on there immediately as mosture will rust it quickly. I drive the car in the rain all the time here in colorado, and am thinking perhaps stripping to bare metal is not the best way for me to go. If I do coat it with krylon clear coat and I go through a winter here, how often would I have to remove the fan to clear coat it?
I had mine powdercoated, but the tolerances between the blades and the housing are small - I had to grid down the paint on the ends of the blades. Which has been an aggravating process of doing so, putting the fan back on, then finding out I didn't remove enough.
DD summer/winter: 2000 Boxster S DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale) http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story |
beancounter
I did au naturale for the fan, and sprayed the housing with Zinc Chromate primer for an aeronautical look.
Jacob Current: 1983 911 GT4 Race Car / 1999 Spec Miata / 2000 MB SL500 / 1998 MB E300TD / 1998 BMW R1100RT / 2016 KTM Duke 690 Past: 2009 997 Turbo Cab / 1979 930 |
1990 964 C4 Coupe & 1991 964 C2 Coupe (current) 1989 911 Targa (sold) 1996 993 Cab. (sold) 1999 x2 Boxster (sold) 2006 Cayman S (my daily) |
Any special paint needed? High temp?
I actually used VHT engine enamel, they make different grades to withstand up to 1500 degrees depending on how much you want to spend. I went with a silver color, dirt won't be as big of a problem as scrathes.
PS get a rennline fan shroud strap from pelican to go on it after you get done with all this work!
Member 911 Anonymous
Bake it too at 200 degree for 15-20miutes, will help.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
To clarify: I'm going to pick up another can of brake cleaner. And nylon brush and clean up the shroud best I can. Then find some black engine enamel and paint it. Then after it's dry just stick it in my oven 200deg 15 mins . Correct?
The chemical solution in many hot tanks will literally make your problem go away. Ask first to confirm. If you want it looking like the factory just produced it, go to the Early 911S Registry forum and do a search on fan restoration or equivalent. Mark is known by his friends as the "fan boy" (guy). Sherwood |
I did this to my brake calipers and they seem to hold up fine in a more harsh environment but the calipers do not see the g forces exerted by the spinning fan. Keep us updated.
Before I painted it.
![]() After I painted it. ![]() So I am doing the same for my strap. I may get a rennlist one, but they seem way too shiny for my old girl. I think it may scratch putting it in just painted tho. I'm baking it too even tho it's probably just aluminum. I'll post more pics as she comes back together. Thanks everyone for all the advice.
Oh no, you suppose to bake when wet.
? Oh. Ummm I did not know that. I'm going to check clearance tomorrow. If good I'll spray another coat and bake wet. I used krylon BBQ grill paint. It dries in minutes. Ok?
Hmm, try it, but keep an eye on it. It may start flaking. Sorry to be the bringer of bad news. I hope I am wrong.
The idea is you want the wet paint to bight the contact surface while baking with any paint.
