pszemia's Avatar
Porsche 911 2.4T 1973 MFI, wich oil and wich fuel?
Hi, i have a Porsche 911 T 1973 2.4 MFI (the lasts ones ) i want to put everything in order on the car because the previous owner was a disaster, a really disaster.
but first things first.
Wich kind of oil should i use? I mean, mineral, semi-sintetic, sintetic and also wich grade 10W-40 20W-50 5W-50, etc..
The car is mainly used on weekends 1 or 2 hours around 60miles and at high speed.
the temperature there is on winter around 10ºC and in summer around 25ºC.
And also i want to know wich kind of fuel use.
Here we have 95 RON and 97 RON and some places 87RON (but very bad quality)
should i add any kind of additive like "liqui moly lead substitute"?
Thanks!!!!
Ariel
Old 12-08-2007, 07:02 PM
Your engine has a very low compression ratio so you can use any quality fuel. In the states that would be 87 octane R+M/2 or above. We call that regular. Your owners manual should specify the requirements for fuel and oil. As far as oil goes, in your mild climate I would use any high quality 10w-30 non synthetic oil. There is a long thread on the inadequacy of the latest generation of oil that you might want to look at.
-Andy
Old 12-08-2007, 07:33 PM
pszemia's Avatar
so i should use mineral oil?
Old 12-09-2007, 02:06 AM
Yip, mineral oil. I'm using 20W50 in my 911t, but I drive the car only wenn the weather is nice (read: warm)
Fuel: use the best you can get and use a lead-replacement every 3 times you tank gaz.
Old 12-09-2007, 02:11 AM
Non-synthetic is just fine. For most users, 15w40 and 20w50 are the most appropriate oils. I don't like 10w30 or 10w40 as most of these oils fall under the pitfalls of the newest API specifications and may not provide sufficient protection (AW additives or film strength). Synthetic 0w40 or 5w40 may be ok, you just need to read the label.
Ultimate Motor Oil Thread or Why we hate CJ4/SM oils
Charles Navarro
President, LN Engineering and Bilt Racing Service
http://www.LNengineering.com
Home of Nickies, IMS Retrofit, and IMS Solution
Old 12-09-2007, 06:02 AM
70SWT's Avatar
"wich oil and wich fuel?"
Given the spelling of which - are you in another country? Could make a difference in your options.
2018 911 Carrera coupe
1972 911T targa
Old 12-09-2007, 07:52 AM
I use Kendall GT 20-50 dino oil and 92 octane non-oxygenated fuel
in my "T" with excellent results. Also, Swepco in the 915 gearbox.
Mike B.
'72 911E Coupe
Early "S" #1065
Old 12-09-2007, 09:39 AM
pszemia's Avatar
thanks everybody
yes, i live in Argentina, and it was too late when i wrote the post.. sorry for the grammar
Old 12-09-2007, 02:48 PM
pszemia's Avatar
i've been looking for some brands and prices, these ones are the best i can get. All of them mineral.
Liqui moly 15W40 8U$S x liter
Valvoline 15W40 5U$S x liter
Shell 15W40 5U$S x liter
Castrol GTX 15W40 5U$S x liter
Motul 15W40 5U$S x liter
Wich one you recommend??
remember the car is stored all the week and used only some weekends.
thankss
Old 12-12-2007, 10:28 AM
Bug Eating Member
frogger's Avatar
I recommend Valvoline.
Old 12-12-2007, 10:31 AM
Which motul is that - the 6100 or 2000 series 15w40? Either would probably be fine. The Tekma diesel oils would also be good. Again, which Liqui moly 15w40 - from what I see, it too is an API SG rated oil. I would go with the Liqui Moly or Motul oils over the big name players liek Shell, Valvoline, or Castrol.
Charles Navarro
Old 12-12-2007, 10:36 AM
Autodidactic user
David E. Clark's Avatar
Originally Posted by pszemia View Post
Hi, i have a Porsche 911 T 1973 2.4 MFI ...
Thanks!!!!
Ariel
According to the last Check, Measure, Adjust manual (#4532.21):
From Model '72 on all engines use 87 octane fuel. Engines operated on higher octane fuel will not run properly since the greater anti-knock capacity (octane number) of the fuel the more difficult the fuel becomes to ignite.
Based on this I would use the 95 RON fuel since this would be equivalent to about 90 octane fuel in the U.S. Your 87 RON (bad quality) gas would probably make the car knock since it would be equivalent to about 83 octane in the U.S. If you can find it, your best choice would be 91 RON which would be just about right at 87 octane U.S.
The valves and seats should be "hardened" in your '73 so there is no need for a lead substitute (although from my experience the additional lubrication provided by the lead substitute certainly won't hurt anything). Hope this helps.
Please help the MFI community keep the Ultimate MFI resources thread and the Mechanical fuel injection resource index up to date. Send me a PM and I'll add your materials and suggestions.
1973 911E Targa (MFI)
Old 12-12-2007, 12:34 PM
