Delusions of Adequacy
Uber-fanatic's Avatar
Do Shift Knob Compression Sleeves Go Bad???...
...or is it just because of cold weather (50 degrees here in LA is considered cold to us!) that my knob keeps flying off on me! Just curious.
1974 911 3.0 (makes me )
2004 Toyota Sequoia
2000 Honda CBR XX1100 Blackbird
Old 12-13-2007, 08:18 AM
emac's Avatar
I had to cut my shift knob off the thing was on so damn tight. Little colder here in Chi Town.
Ernie 81 SC
Old 12-13-2007, 09:38 AM
burgermeister's Avatar
My factory shift knob just unscrewed. I figured the threaded rod was part of it. Found out later it's a bolt ... but still, the knob just screws back on. I have not had to take the cap off t get at the bolt head. I've since turned a shift knob from cherry, tapped it for an 8mm thread 1" deep, and screwed a 2" piece of 8mm threaded rod into it. It also just screws on and off the lever. The hand-built eccentricity keeps it tight enough so it doesn't move on its own.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-13-2007, 04:39 PM
You might want to look very closely at the knob itself to see if the neck in which the sleeve fits has started to crack. The same thing happened in my 75 but the neck was obviously split. It's possible yours is weakened, allowing the sleeve to lose its grip on the lever.
L.J.
Recovering Porsche-holic
Gave up trying to stay clean
Stabilized on a Pelican I.V. drip
Old 12-13-2007, 04:53 PM
