gungadin's Avatar
Mis-fireing back fireing problem
This is a '76S with a '79 SC engine and points igintion.
I had this car tuned up and I put several hundred miles on it and it started to develop this problem.
Cold it runs smooth. As it warms up it developes a random misfire backfire and the hotter it gets the worse the problem.
It doesn't misfire if I put my foot into the accelerator hard but if I try to accelerate moderately or just maintain a speed it misfires.
When it is misfireing I can see the tachometer drop rpms instantly. The worse the misfireing the more rpms are not being displayed.
I just put new spark plugs and new plug wires in it but no change. The cap and rotor are new.
This problem coincides with a change in the weather as it has been raining quite a bit lately and I don't remember it doing this at all before the rains.
Although it wasn't raining this evening when I drove it just after the new plugs/wires.
Suggestions are welcomed and greatly appreciated
Old 12-19-2007, 12:48 AM
UnRegistered User
billybek's Avatar
My 83 SC does a similar thing after a good long highway run. When speed is moderated and running about 2700 rpm the engine kind of fires against itself. Pulls like a freight train under acceleration though.
Watching this thread with interest...
Bill K.
Old 12-19-2007, 05:46 AM
Designer King
Paulporsche's Avatar
I would check the points/dwell angle first.
It's also posible it's your WUR/warm control pressure and/or mixture.
Make sure your plug wire ends are snapped on firmly. Also, new wires can be bad.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 12-19-2007, 01:45 PM
Read your other thread on this problem; about a coil.
Old 12-19-2007, 02:04 PM
