wkubasak
Guest
Posts: n/a
Question 911 Struts
I have front struts with Koni inserts. The struts are threaded on the inside at the top. Does anyone know if these are Boge struts or Koni struts.
Old 03-12-2001, 08:07 PM
feelyx
Guest
Posts: n/a
Porsche Crest
What color are the struts? Generally orange is koni, black is boge.
Old 03-12-2001, 08:15 PM
Early_S_Man
Guest
Posts: n/a
They sound like Konis, but the mfr is stamped into the strut, along with the part number ... low on the strut around where the knuckle is welded. You should be able to find the stamped markings if you clean the struts, and look.
Warren Hall
1973 911S Targa
Old 03-12-2001, 08:20 PM
wkubasak
Guest
Posts: n/a
Post
Thanks for the suggestions. I'll try looking for the manufacturer's stamping.
Old 03-13-2001, 08:36 PM
ZE911
Guest
Posts: n/a
Post
The boge struts have threads at the top where the cartridge is secured. The Bilsteins are green and have a roll pin at the bottom of the strut housing.
Old 03-14-2001, 08:45 AM
