-   -   Switched 12v source at coil (http://forums.pelicanparts.com/porsche-911-technical-forum/382564-switched-12v-source-coil.html)
jmshepard 12-15-2007 10:41 AM
I need a switched 12v source in the engine compartment. Is there any potential problems using the 12v connection at the coil?
Thanks,
Jim S.
ischmitz 12-15-2007 10:56 AM
Both the 993 and the SC should have a switched +12V at the relais pannel in the engine bay I would prefer that over the coil since it will have less transient spikes.
Check the three fuses in the panel. If I remember correctly one is hot all the time and the other two are hot with the ignition to ON.
Ingo
jmshepard 12-15-2007 10:59 AM
Thanks Ingo, I checked that one but it is only providing 9.6v for some reason.
