Solvent recommendation needed
Can anyone recommend a solvent to remove the glue from double sided tape. This solvent must be paint/clearcoat friendly.
Thanks & Merry Xmas to all !
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
UnRegistered User
Try a small amount of Rubbing alcohol...
Bill K. "I started out with nothin and I still got most of it left...." 83 911 SC Guards Red (now gone) And I sold a bunch of parts I hadn't installed yet. |
Just about anything will remove that. 3M adhesive cleaner, WD-40, bug and tar remover...
JR |
Try with a heat gun as well. It helps.
Mineral spirits or paint thinner (NOT lacquer thinner) works well too ...
'88 Coupe Lagoon Green "D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen" "We must not allow a Mineshaft Gap!" |
a couple of products, one called Goo Gone and one called Goof Off. or, if you have a lot to do. buy an eraser wheel for your drill from the auto paint supply.
I think I used 2 full cans of that when I did a roof liner install.. if so it's good stuff.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Thanks fellas...
Regis turd ab user
Naptha, aka lighter fluid, as in Zippo.
Not hot at all and won't harm paint |
