liquid transfer tool
what are you guys using to transfer/pump fluids from a container to a trans or something? I am tired of crawling on the floor under what ever part of the car to change trans fluid, or to change the dif fluid in my truck...
Are the $20 long egg beater battery powered ones any good? I would rather spend the "going/right" amount to get the correct unit once and for all! Thx Bob
I live for 911 tweaks... |
abit off center
I used my pump up brake bleeder which I didn't like for doing the brakes so its now filled with gear lube. Or you can get a 12v oil change kit from any boating place, used for changing oil below deck, they work very well because you can reverse the pump and suck it out too.
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. Last edited by cgarr; 12-23-2007 at 04:28 PM.. |
i just stuck a garden hose in my tranny, a funnel on the other end. Started pouring standing up beside the car. When it was full I stopped pouring. It was all I had to work with and it seemed to do the job effectively.
Here's my story on how I got mine changed.
When you reach that happy moment that you will add the new oil back into the transmission, jadams1 has a great addition to my funnel method: ![]()
Registered Abuser
Pelican
SL4344 pump ![]() These work great! painless & cheap.
MT 930 1987 930 - Gone but not forgotten A man with priorities so far out of whack doesn't deserve such a fine automobile. I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen американский |
915 Trans. Oil Filler......
Picture of my 15-year old home-made 915 trans. oil filler procured from local hardware store. It is so convenient and less messy using a rigid tube than flexible plastic hose that I saved this gadget for my routine trans. oil change.
![]() ![]() Tony |
With all due respects to Pelican's part, Harbor Freight manual transfer pump, <$10.
All the other solutions seem like two-man tools with required gaffer accessories. Sherwood |
Irrationally exuberant
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ Last edited by ChrisBennet; 12-24-2007 at 07:07 AM.. |
I've used a "Mity Vac" hand pump with success.
'73 911 Frank 'n Meanie 2002 Boxster S PCA Instructor Circa '95 |
thanks guys! I think I will try the "Stearns Quick Change Oil Change pump" offered @ discountmarinesupply.com as it uses 12v and I can flip a switch ON or OFF when I want and it appears that I won't be getting dripped on & covered in lovely sulfer stinkin' diff fluid anymore...I hope :-)
I'll let you all know how it goes. Thanks again and Merry Christmas / Happy Holidays everyone!! Bob
