Nine9six's Avatar
Solvent recommendation needed
Can anyone recommend a solvent to remove the glue from double sided tape. This solvent must be paint/clearcoat friendly.
Thanks & Merry Xmas to all !
If it flows, it goes. If its smooth, it moves. Any questions?
96 993 C2 (Current)
87 911 Factory Turbo-Look Cab (Sold)
85 911 Factory Turbo-Look Targa (Gone)
Old 12-16-2007, 04:50 PM
UnRegistered User
billybek's Avatar
Try a small amount of Rubbing alcohol...
Bill K.
Old 12-16-2007, 04:53 PM
Just about anything will remove that. 3M adhesive cleaner, WD-40, bug and tar remover...
JR
Old 12-16-2007, 04:54 PM
old man neri's Avatar
Try with a heat gun as well. It helps.
Old 12-16-2007, 04:59 PM
burgermeister's Avatar
Mineral spirits or paint thinner (NOT lacquer thinner) works well too ...
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 12-16-2007, 05:04 PM
haycait911's Avatar
a couple of products, one called Goo Gone and one called Goof Off. or, if you have a lot to do. buy an eraser wheel for your drill from the auto paint supply.
Old 12-16-2007, 05:06 PM
Originally Posted by haycait911 View Post
Goof Off. .
I think I used 2 full cans of that when I did a roof liner install.. if so it's good stuff.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 12-16-2007, 05:58 PM
Nine9six's Avatar
Thanks fellas...
96 993 C2 (Current)
Old 12-16-2007, 06:01 PM
Regis turd ab user
Naptha, aka lighter fluid, as in Zippo.
Not hot at all and won't harm paint
Old 12-16-2007, 06:23 PM
