wiring issue
I have a problem with my 75 911s,, the high beam are always on when the lights are on,even the small blue light in the dash is on, ,I have seen the diagrm here but it either 73 or 82,, which on is the right one,, once I have that it will surely help
an other note or may be the same , i had to rebuilt the steering column and noticed that half of the circular connector were undone, so they are in as .... which one is which , they all can connect in all the spots thanks for the help guys on
9140431696 painted, with wheels and brake , with all elctrical working , engine in assembly soon to be driven 011850275 911S soft window targa next in the garage 2000 S4 stage 2 660R stroked |
Take a look at the pictures and writeup from this thread:
turn signal switch quick fix pictures The thread below describes a similar problem: Turn signal / high beam switch
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? Last edited by MBAtarga; 01-02-2008 at 05:59 PM.. |
You need a new turn signal switch, not a wiring diagram.
I had the exact same problem, turned out the turn signal/high low beam stalk was bad, here's a pic of the problem:
![]() Here's a thread I made detailing the problem: Photo of bad turn signal/high low beam stalk
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
