drag racing the short bus
dd74's Avatar
Rear shock question
Am I correct to think an alignment, ride height adjustment and corner balance aren't required when R&R-ing the 911's rear shocks?
The Terror of Tiny Town
Old 12-20-2007, 05:25 PM
Todd Simpson's Avatar
Correct on all fronts.
Old 12-20-2007, 05:34 PM
Unless,......................unless one is installing Bilstein shocks instead of Boge or Koni's.
These high-pressure gas shocks will raise the ride height anywhere from 1/4" to 3/8" and that requires a re-alignment.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 12-20-2007, 05:45 PM
dd74's Avatar
But what if I like that ass-high look?
Old 12-20-2007, 05:50 PM
Ahhh,...thats a horse of a different color (and breed),...
Raise 'er up and do the Trans-Siberia Rally,....
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 12-20-2007, 06:18 PM
I can atest to the height increase when I install the Bilstein HD's as replacements to the Boges. My car was ready for the Paris-Dakar Rally. The American road height was bad enough, but when I installed the Bilsteins, it was up up and away. Presently my car is in the process of being lowered, corner balanced and aligned, as well as receiving new torsion bars, poly-graphite bushings and turbo tie rods. Can't wait til its done.
Scott
___________________________
1985 Carrera Targa - Guards Red
2006 Acura TSX Navigation - Milano Red
Old 12-20-2007, 06:26 PM
dd74's Avatar
Yep - I'm trading my 911 for a '70 Camaro.
We have one of those cars driving around here. Works great when the San Fernando Valley floods.
Old 12-20-2007, 06:28 PM
If you measure the height before you do the swap and then adjust the spring plates to get the same height after ward the rest of your alignment will be fine. You must make sure to move both sides the same amount for this to work.
-Andy
Old 12-20-2007, 09:23 PM
Won Won is offline
Won's Avatar
Going from my old, dead (presumably) factory shocks to Koni yellows I gained a good inch of height in the rear.
83 911SC Targa
Everything I say is my personal opinion, and has nothing to do with my team.
Old 12-20-2007, 09:24 PM
Jeff Alton's Avatar
Totally incorrect actually, for many of the reasons stated. One will actually see a differnce with Koni adjustable shocks as well as the bilstien.
If your shock replacement results with an "as before" ride height, then yes, you probably do not need an alignment or corner balance.....
Cheers
www.turn3autosport.com
Old 12-20-2007, 10:45 PM
Jeff Alton's Avatar
-Andy
Again, you can "jack" wieght into the car even with a similar ride height. Though not normally from just playing with one end of the car. But I have done it with screwing with both ends......
Cheers
Old 12-20-2007, 10:46 PM
