Electrically challenged...
Seasons Greeting and Salutations fellow Pelicans...
I was hoping someone could help me isolate this problem, and please remember I have come right out and indicated that I am electrically challenged. My RR tail light turn signal works, my RR brake light works... When I turn the lights on, the RR driving lights do not work. I have swapped bulbs L-R with known good bulbs, and still no lights. Could this be my light switch under the dash? I bought the switch from a fellow Pelican, when my original peformed its best rendition of the end of the tape, in a Mission Impossible episode. This message will self destr....fiseseegfttgggst. While anything is possible, I was hoping someone may be able to offer some suggestions. P.S. The lights worked fine when I initially replaced the switch. Thanks in advance fellas... Merry Christmas to all, and to all a good night...
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Verify the right front running light does not work either. If it does not check fuse box 2 fuse 6 and go from there.
else keep looking
Rick 88 Cab |
Ooops nevermind, those are the turns signals.
EDIT: Wait a minute there must be some error in the Bentley. The only lights it shows coming on with the switch in the park position are the license plate lights. I'll check my Factory manual when I get home.
Rick 88 Cab Last edited by rick-l; 12-21-2007 at 09:53 AM.. |
Probably a bad ground on that side. I would make a jumper to ground and see if they work.
Tony Proasi 1969S 1957 VW Pickup |
