-   -   steering column movement (http://forums.pelicanparts.com/porsche-911-technical-forum/38367-steering-column-movement.html)
Panic_Rev 03-18-2001 09:05 AM
I have some movement in my steering column and was wondering if anyone out there has had this and what did you do to correct the problem. I have read articles talking about the column bushing wearing out. Has anyone replaced this part and how much work was involved? I have an '83 911sc. Thanks in advance.
rcilurso 03-18-2001 09:14 AM
Check out the tech article on bushing replacement. It's not that tuff.
http://www.pelicanparts.com/techarticles/911_Steering-bushing/911_steering_bushing.htm
rj cilurso
87 911 targa
[This message has been edited by rcilurso (edited 03-18-2001).]
davis911s 03-18-2001 09:54 AM
you can also get a metal sleeve that you can replace, this is the easiest way to go, it is supposed to be way better. It is Porsche part # 928 347 739 02 I have one for mine but haven't installed it yet. It's an inexpensive way to go and all you do is remove the wheel and press it in.
Shawn
