-   -   Consequences of a Botched Valve Adjustment? (http://forums.pelicanparts.com/porsche-911-technical-forum/38418-consequences-botched-valve-adjustment.html)
Dropp the Pilot 03-20-2001 02:52 AM
Just curious, what would happen if this was done completely wrong? Power loss? Damage or excess wear of cams and valve stems?
Jon Green 03-20-2001 03:20 AM
Depends how you botch.
Excessive clearances will lead to increased valve train wear, mushroomed tappets etc. & loss of power.
Too tight & you will burn an exhaust valve.
As clearances open up you can hear it, & do something about it.
Too tight is the one to advoid every time.
If you've ever done the clearances on a VW beetle the 911 is really not too different,
nothing to be scared of. The Pelican article explains the procedure very well.
Regards, JG
