What is this sensor?
I stole this pic from another thread.. but what is the sensor in the lower left? Mine is broken and disconnected.. wondering how it would affect the engine. Mine is a 76' 911s.
JP
'76 911s Ice Green Metallic bone stock
Old 12-28-2007, 03:18 PM
3.2 CAB's Avatar
Hi, I could not see whatever you were talking about. Label it like the other items labeled, that way we can see what you are talking about. Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 12-28-2007, 03:38 PM
JP
Old 12-28-2007, 03:42 PM
911quest's Avatar
The one on the timing chain cover? If so it is basically a temp sensor.
Tony Proasi
1969S
1957 VW Pickup
Old 12-28-2007, 03:43 PM
If it is it is not the one for my gauge. So what needs it? My car is missing badly and I just replaced plugs and cables.. rotor and cap on the way.. BUt I just noticed this sensor is broken and the cable is just hanging there with leftover parts.
JP
Old 12-28-2007, 03:45 PM
911quest's Avatar
Its for the fuel injection. It controls the cold start operation. most of them are disconnected I have found for a reason usually they are bad and cause slow cranking or hard start problems this is just from my experience. I doubt it has to do with your rough running concern.
Tony Proasi
1969S
1957 VW Pickup
Old 12-28-2007, 03:49 PM
Okay, thanks.. I'll rule that out then.
JP
Old 12-28-2007, 03:53 PM
Thermotime Switch.....
JP,
That's a thermotime switch and a critical CIS component for cold starting. The CSV (cold start valve) will only work when properly grounded via this switch. The red/brown wire goes to the big connector and the yellow wire goes to the smaller connector.
If the TTS is disconnected or defective, it could either effect your cold start or flood the manifold with extra fuel.
Tony
Old 12-28-2007, 04:42 PM
Originally Posted by boyt911sc View Post
JP,
Tony
Right now my car is doing several things.. when I start it it is hunting like crazy.. as though it has an intake leak. It also doesnt seem to be fireing on all cylinders when I hold the throttle down a bit.. It has a Permatune and I am starting to think its a bad unit.. cap and rotor should be here monday.. once I replace them I am going to really suspect the permatune.. But I better order this sensor too.
EDIT: from a cold start it runs for 30 seconds with a nice idle.. then it starts to drop cylinders.
JP
Old 12-28-2007, 04:48 PM
