Question 81 sc rpm surge
Starts up great but after a few seconds RPM surges from 4/500 to appx. 1500 and then drop back to 4/500. Will die when pull up to traffic light. Help!
Old 08-06-2009, 08:25 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
From personal experience,
this is just one of the many possibilities.
Check these vaccum lines from the back of
the air meter to the fuel pressure regulators.
If you remove your oil filler cap, any change?
Also your idle rpm's should be around 850-950.
Is your idle set correctly?
Good luck,
Gerry
Old 08-06-2009, 08:37 AM
Brother's Avatar
It should idle higher than 400-500. It should be more like 850+/-50 if I remember correctly. There is a large spring and flat head screw assembly front and center on top of the CIS. You can turn that to raise the idle.
I had a similar problem when I drove up to high altitude.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 08-06-2009, 08:40 AM
Gerry/Brother
Thx for the quick reply-I'll investigste.
Old 08-06-2009, 08:59 AM
gulkster's Avatar
as an aside, I have no way to turn that screw with a screw driver with everything installed, so you just need to use your fingers.
T-Shirt wearing, sticker toting, SCWDP registered member
Why when you misplace something is it always found the last place you look? Because you stop looking after you've found it
'83 911sc ROW Targa
'84 BMW 320i (what did I get myself into?!)
Old 08-06-2009, 09:34 AM
Designer King
Paulporsche's Avatar
If it is a rhythmic up and down fluctuation of the speed, it is usually a too rich mixture.
If it holds a speed, then drops, comes back up, holds and repeats, then it is often a too lean mixture.
There are various reasons for this. Has this symptom suddenly appeared?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-06-2009, 11:25 AM
