e p slick's Avatar
Accumulator purpose
Am I correct in presuming that the CIS Accumulator is only used/necessary for engine starting fuel pressure and that it has no other purpose?
Input appreciated. Thanks - EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. -
Old 01-08-2008, 03:07 PM
Senior Member
Superman's Avatar
I have heard it also helps to muffle pulses in the system fuel system. It protects other components from spikes in fuel pressure, etc.
Mocha 1978 911SC. "Coco"
Old 01-08-2008, 03:12 PM
CIS Fuel Accumulator....
According to Bosch Technical Bulletin:
Fuel Accumulator
"The fuel accumulator maintains the pressure in the fuel system for a certain time after the engine has been switched off. When the engine is running it serves to deaden the noise of the electric fuel pump".
Old 01-08-2008, 07:40 PM
