http://www1.istockphoto.com/file_thu...usty_blade.jpg Randy |
My engine was getting so hot that it was losing significant amounts of power when it got up there - like nearly 25% loss of power according to my butt dyno. Not this time! Am making all the cooling mods I can get my hands on during the rebuild... |
Still doesnt make sense to me.. but ok.. anyway.. back to the nutcracker thread.. ;) |
The dremel tool and a set of diamond edge cut off wheels is the trick. Just slice the nut in a couple of places, not all the way to the threads though, and then just use a small chisel to open the nut. It will just spin off at that point.
It takes a while, but the local Princess Auto (Canuck equivalent of Harbor Tools) sells a 3 pack of diamond dusted cut off wheels for about 8 bucks (or $693.50 American at current exchange rates) and they slice through quite easily..... Dennis |
Thanks for all the input (except for the rusty butterknife:eek:)
I may in fact give up. Taking the tstat off was just one of many things I'm doing in an effort to diagnois high temps. Everything I can do to diagnois tstat with it on the car says it's actually OK - but the only way to be sure is to get it out, if getting it out were easier it might be worth the effort, but based on the probability that it's ok - and that I'll ruin it or something else in the process.... I think I should just stop. |
Cooling issues can be really frustrating. Take a look through the archives, there are some REALLY good threads. If none of those help, start a new thread. I agree, ditch removing the 'stat (for now).
Did the car ever cool well, or has there been a recent change in your operating temps? |
Ducman,
Maybe I missed the post where you removed the entire thermostat and oil lines from the vehicle. Removing the cooler lines from the thermostat on the vehicle is a difficult job due to the aforementioned corrosion and the limited access to work angles. Dropping the entire systems doesn't take long. On the bench or ground, there's easy access for any manner of removal suggested, either by cutting the oil line fitting with a Dremel or equivalent or using heat with Kroil or PB Blaster and a couple of wrenches and 3 foot handles. However, your latest assessment of your heating issues is correct. I'd step back and think this through and confirm the problem is not something else, then proceed. For example, if the supply the line to the cooler is cold or at least not hot, that would indicate partial or full blockage (bypass) at the thermostat. Check the easy stuff first (debris in engine, slipping drive belt, incorrect timing, incorrect heat range spark plugs, etc.). Hope this helps, Sherwood |
I agree w/Sherwood - definitely drop the the thing as a unit before doing anything more drastic.
If the cooler lines under the passenger-side rocker got hot, then that thermostat is probably not your problem. The first thing I'd check is the engine-mounted cooler. That is your first line of defense.
As always, listen to John. Not listening to John, which I have done a couple of times, is a mistake. When I changed my lines, I fought with those nuts and eventually won. I used copious amounts of Maltby's penetrant over several days. I used heat. I wedged a block of wood between the wheelwell and the thermostat, to help hold it steady. I probably also used a LARGE channel-lock to help hold it still. It came off. |
Stuck nuts!...............
I did this job a while back. I pulled the entire assembly off the car and then made this wrench to remove the stuck nuts.
http://forums.pelicanparts.com/uploa...1199315896.jpg http://forums.pelicanparts.com/uploa...1199315923.jpg It is made out of a piece of 1/2" thick steel with the hex cut out with a dremel tool and finished with a sharp file! It has enough mass to transfer the hammer blow effectively to the nut. A few whacks with a large ballpeen hammer and off they came! |
Fred,
That would be the ultimate flare-nut wrench. Drilled holes for lightness? :) I was happily successful with the Porsche oil line wrenches and lengthy pipe extensions. For future DIYers, don't forget to apply copious amounts of anti-seize on the delicate al. threads before reassembly. Apparently, the factory fell short in this area. Sherwood |
Would it be better to try an oxy/acetylene torch on those threads? I am just thinking out loud for future reference. I used to use a propane torch but one day I saw the light with oxy/acetylene and haven't met a stuck bolt or nut since.
Sherwood |
| All times are GMT -8. The time now is 04:14 AM. |
