-   -   Rear SC disks: should I machine them? (http://forums.pelicanparts.com/porsche-911-technical-forum/385094-rear-sc-disks-should-i-machine-them.html)
Vincent 911 01-01-2008 05:49 PM
I am currently working my braking system on my 78 SC.
My rear rotors are 19.0 mm thick.
The new thickness is 20.0 mm and the wear limit is 18.0 mm. So they are right in the middle of the range.
Should I machine them (cheaper: my machinist does them for 10$ / rotor) or buy a new set (more expensive)?
Thanks and happy new year.
yelcab1 01-01-2008 06:32 PM
If you want to save money, I would machine them. Specs are specs, if they are thicker, they are OK.
mark_d_mcguire 01-02-2008 06:27 AM
Why are you machining them? Are they grooved or greatly uneven?
Unless there is something wrong with them there is no reason to do anything. Slap some new pads on and go.
If there is something wrong, then they will probably be out of spec by the time you're done anyway.
Porsche_monkey 01-02-2008 06:35 AM
If they a warped they will warp again, likely very quickly, if you machine them.
If they are rough I would take light cut only.
Vincent 911 01-02-2008 08:23 AM
They are not wrapped but the surface is quite rough (ciruclar scores). I don't want to ruin a new set of pads on this rough rotor surface.
Porsche_monkey 01-02-2008 08:30 AM
I would take a light cut and remove most of the roughness, they don't have to be perfect.
