Guest
Posts: n/a
Does anyone have a part number for the fan/alternator belt for a 1983 911sc. Trying to install a new belt today I could not get the tension correct even with all seven shims to the outside of the assembly. I believe the dealer may have sold me the wrong part. It's number is 999.192.097.50. This number does not jive with the P/N in the Automotion catalog and their PN's are usually pretty accurate.
Thanks |
Guest
Posts: n/a
Rich,
That is indeed the wrong belt, a 9.5 mm x 725 mm size for '76-'79 models. What you need is a 9.5 mm x 710 mm size. ------------------ Warren Hall 1973 911S Targa |
Guest
Posts: n/a
Thanks a ton Warren.
Guest
Posts: n/a
My latest spare is a Continental brand with notches on the inside, and is a 10 mm x 710 mm, and carries the p.n. 999.192.176.50. I'm pretty sure the width change from 9.5 mm to 10 mm doesn't make any difference.
Guest
Posts: n/a
The belt on my 78 911Sc is 10x710, and it fits fine with three spacers on the outside of pulley, the rest on belt side. I too was sold the 10x725, lucky it was a backup that I never needed.
