Gasket Material Needed
I need some very thin gasket material. .010 or .005 preferably. It's for a fuel shut-off valve, so it needs to be fuel resistant and able to withstand the valve "ball" rotating against it. Paper material won't work.
Suggestions would be appreciated. Sources for purchasing a relatively small amount would be appreciated too. Thanks. Scott
1984 Targa |
abit off center
Might try a pure alum shim stock like this one 9536K14 from http://www.mcmaster.com/
______________________ Craig G2Performance Twinplug, head work, case savers, rockers arms, etc. |
Interesting idea. I'd never considered aluminum as a gasket material.
Thanks!
1984 Targa |
How about copper?
You're not going to be flying around with an experimental gasket in your fuel valve are you? :-)
pozee |
A friend of mine who does a lot of work on vintage motorcycles makes thin aluminum shims from aluminum drink cans.
Steve B. 1972 911t 1999 328is |
