richenry
Guest
Posts: n/a
Post P/N for fan belt!!
Does anyone have a part number for the fan/alternator belt for a 1983 911sc. Trying to install a new belt today I could not get the tension correct even with all seven shims to the outside of the assembly. I believe the dealer may have sold me the wrong part. It's number is 999.192.097.50. This number does not jive with the P/N in the Automotion catalog and their PN's are usually pretty accurate.
Old 03-22-2001, 03:45 PM
Early_S_Man
Guest
Posts: n/a
Post
Rich,
That is indeed the wrong belt, a 9.5 mm x 725 mm size for '76-'79 models. What you need is a 9.5 mm x 710 mm size.
Warren Hall
1973 911S Targa
Old 03-22-2001, 03:59 PM
richenry
Guest
Posts: n/a
Post
Thanks a ton Warren.
Old 03-22-2001, 04:03 PM
Early_S_Man
Guest
Posts: n/a
My latest spare is a Continental brand with notches on the inside, and is a 10 mm x 710 mm, and carries the p.n. 999.192.176.50. I'm pretty sure the width change from 9.5 mm to 10 mm doesn't make any difference.
Warren Hall
1973 911S Targa
Old 03-22-2001, 04:16 PM
Serge
Guest
Posts: n/a
Post
The belt on my 78 911Sc is 10x710, and it fits fine with three spacers on the outside of pulley, the rest on belt side. I too was sold the 10x725, lucky it was a backup that I never needed.
Old 03-22-2001, 06:02 PM
