Ignition Coil Options
I've verified that my ignition coil is dead. Car starts right up with a coil fromna running car.
Help - My Car Won't Start What are my options on a replcement coil for a 1987 911? Is the silver Bosch TCI Coil the only option? It had a back coil with an orange top Bosch TCI - seems this is no longer available. I have a MSD Blaster 8202 coil would this be an acceptable replacement?
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint |
Early_S_Man posted that the MSD "vibration proof" coil is a good match for the Bosch CDI unit...I forget the MSD number...it's a black coil, "potted", so it can be mounted in the original position.
The silver Bosch (made in Brazil?) coil does NOT have a good reputation for reliability. Warren Hall...sorely missed.
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Those are the best option for the Carrera (non-CDI) and still available,...
![]() Last I checked, they were around $ 121.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
So to answer my question, can I use the MSD Blaster 8202 with the motronic ignition system?
If I'm not mistaken, Steve just said yes...
just me
how does an msd ignition function compared to a stock ignition
I have an 87 engine. how is it better or worse?
1975 911s, 3.2l and 915 transmission front oil cooler RUF replica bumper ducktail and SC rear flares SW chip ssi's m&k 2 in 1 out sc front calipers PF 97 pads fuchs 16 x 7 and 8 225/ 245 toyo ra-1s 22/29 torsion bars 25mm Charlie Bars Neatrix bushings lowered and corner balanced DAS bolt in roll bar kirkey seat 5 point harnesses. http://www.hairydoggrrrage.com/ |
I think he was refering to the Bosch coil.
Steve?????
Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 01-04-2008 at 07:07 PM.. |
Hi,
What our host carries is MSD High-Vibration Blaster Coil MSD PN8222. Are they the same thing?
'87 3.2 Targa |
