I would like to dedicate a thread of your most personal memorable Early_S_Man posts
I would like to dedicate a thread of your most personal memorable Early_S_Man posts.
My most memorable (among his many) was a reply he made to a question I asked June 8th. 2002. I’ve never forgotten his reply due to it’s detail, his walking the extra mile to post reference threads, and his specific statement that... " This kind of miss doesn't show up until summer temps above 85° F!!!" Here’s the excerpt from the thread: 6-8-02 My question: Have I burnt valve(s) (or worse)? 6-8-02 Ran the car hard today. Toward the end of my drive, I accelerated hard, high rpm. After that I noticed and felt a definite miss. Pulled the plugs, most of them looked dry, and brownish on the top, some carbon mostly on the top of the spark plug threads. No smell of fuel. I can start the car, but very low idle, almost a stall, and if I drive, still a miss. 69 911 "Little Bull" His response as follows: [QUOTE=Early_S_Man;464559]Do a compression test ... burnt valves don't seal well! Check your ignition cables for end-to-end continuity (3000 -4000 Ohms) ... high temps can lead to a miss if a Beru connector is open ... wouldn't happen when engine cool! This kind of miss doesn't show up until summer temps above 85° F!!! Read the following threads for more info: http://forums.pelicanparts.com/porsche-911-technical-forum/70180-beru-connectors-vw-same.html?highlight=beru http://forums.pelicanparts.com/porsche-911-technical-forum/70650-sparl-plug-wires.html?highlight=beru http://forums.pelicanparts.com/porsche-911-technical-forum/7497-ignition-wires.html?highlight=beru[/QUOTE] Thank you Warren Hall Jr. for your sharing and so many memories. ;):p Kirk |
| All times are GMT -8. The time now is 01:27 AM. |
