Reversing the Central Locking light logic 87
I don't lock my doors when I'm in the car because of the annoying bright light from the Central Locking switch. Has anyone reversed the logic so that the light is on/bright when the doors are unlocked and off/dim when locked?
Thanks,
Jeff
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 01-03-2008, 06:10 PM
911 addict
mtbguy's Avatar
Hi Jeff- I have only had my 87 model a year and don't know what previous owners may have done, but it is bright if they are unlocked and if I lock them it goes out (or very dim).
I lock them to get the light to go out. - I wonder if the switch has leads that can be reversed accidentally/on purpose like some others in the car?
1987 Carrera Cab
Toyota Landcruiser
500SL
Old 01-03-2008, 07:19 PM
Perhaps we should trade cars. lol.
01 740i Sport
03 Honda Odyssey
Old 01-03-2008, 07:28 PM
Super_Dave_D's Avatar
What - the central locking button lights up???? Great, something else to fix!! Learn something new every day!
2015 Audi S3
1988 Carrera Coupe (gone and miss her)
Old 01-03-2008, 07:33 PM
Registered Abuser
MT930's Avatar
Same thing mine goes dim locked. Bright Unlocked.
MT 930
1987 930 - Gone but not forgotten
A man with priorities so far out of whack doesn't deserve such a fine automobile.
I would rather wake up in the middle of nowhere than in any city on earth - Steve McQueen
американский
Old 01-03-2008, 07:41 PM
Good news! I guess my car has been broken for the last 18 years. What I need is repair, not modification. I am looking in my Bentley and perhaps the YELLOW and BLUE wires are reversed to the Central Locking switch. Are there numbers on the switch (11, 12) that indicate where the wires go. Any advise/write up on how to remove the switch panel? Wheres the CL ECU located? Guess I'll do some searches.
Thanks,
Jeff
01 740i Sport
03 Honda Odyssey
Old 01-03-2008, 09:17 PM
charleskieffner's Avatar
have you ever seen what happens to doors on a car that is doing endos or a singular/multiple rollover???
lock yer doors and put some black electrical tape over it!
Old 01-04-2008, 03:32 AM
The switch in my center console measures good. I took apart the Central Locking ECU and the wires are hooked up like the bentley says. I guess I'll open up the doors next to see if I can find the problem. Anyone have a CL ECU part# 91161811301 they don't need?
Jeff
01 740i Sport
03 Honda Odyssey
Old 01-07-2008, 08:18 PM
I've always heard that reasoning but I don't know that most crashes would actuate the door handle side of the latch mechanism. I don't believe "locking" the mechanism changes the force it is able to hold before it is defeated. It may be good practice to help avoid car jackings at least?
Old 04-01-2008, 12:55 AM
Wholly Bejeez! Multiple endos I was thinkin' electrical tape myself - but not for that reason! Must be the fear of people driving at high rate o speeds in them AZ deserts!
Old 04-01-2008, 03:06 AM
dshepp806's Avatar
That light beeping sound drives me NUTS!!!!!!!!!!!!!!
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 04-01-2008, 04:31 AM
tkosier's Avatar
me too
Jeff, did have you figured it out yet? My 88 does the bright light when locked, light off when unlocked too!
1988 Carrera
Old 04-01-2008, 01:44 PM
aj88cab's Avatar
Well here's a little April Fool's joke from our friends at Porsche. If the lamp is not working you are SOL. It is soldered in place. Curiousity got the best of me, and like Super_Dave_D said, I just had to fix it. I took the cover off and this is what it looks like. As you can see the lamp isn't going anywhere unless you've got better soldering skills than me (which is very little). The non-working lamp hasn't been an issue until now, so I will just button it up and fugetaboutit.
Notice from the pictures that the little white "reflector" around the bulb is removable. Leave it off or hit it with a black permanent marker and the brightness will be reduced. Maybe it won't be so noticable if it is less bright.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 04-01-2008, 02:34 PM
dshepp806's Avatar
...or, remove the bulb...
you'll probably still hear that annoying beeping tone....(if it's like an '89) The beeping tone is, by far, more annoying than the light (for me)..
Middle Georgia
Old 04-01-2008, 02:36 PM
timeless beauty
rcaradimos's Avatar
My 87 has no audio sound, when locked it gets bright... dim when unlocked. Last year I installed a key-less remote that works great, auto locking doors at start-up and unlocking on shut down.
Old 04-01-2008, 04:45 PM
tkosier,
Nope, never did figure it out. It's good to hear that I am not the only one with "bright light when locked ". Gives me new hope that someone out there knows how to fix this problem.
Jeff
01 740i Sport
03 Honda Odyssey
Old 04-02-2008, 06:39 PM
01sport,
I had the same issue in my '88--bright when locked, dim when unlocked--extremely annoying. There was an aftermarket alarm installed in the car by the PO. I removed it and the behavior reversed--dim when locked, bright when unlocked.
Do you have an aftermarket alarm?
-Terry
Old 04-02-2008, 07:41 PM
Terry,
As a matter of fact I do have an after market alarm. It is a Hofco that was installed in 1987 in beautiful Culver City California. This alarm has been disabled since the early 90's. I took out the "top down motion sensors" a few years ago. Perhaps it is time I removed the rest of the stuff. Thanks for the tip Terry.
Jeff
01 740i Sport
03 Honda Odyssey
Old 04-03-2008, 06:23 PM
