Trotskyite
Revving an engine before shutdown?
Please bear with me on this one, I am slowly debunking a lot of the car myths I was raised on. I was taught to give a car one last quick rev as I turn off the ignition. I was told it primed the carb for the next startup, and I see the logic and how it doesn't apply to a more modern fuel injected car. Is there any benefit for any fuel system, or is it a flawed practice entirely?
Registered Usurper
Another interesting question is "How to properly warm up my 911?", the answer to which is counterintuitive to many people's thinking.
'82 SC RoW coupe |
Trotskyite
Okay, I'll bite. How do I properly warm up my 911? I can't be doing it right, it takes forever to get past the first hash for me. I'll be halfway to work before I feel confident in giving her some revs, and I have already missed my on-ramp opportunity by then
I've always been taught that blipping the throttle prior to shutting it down is detrimental to engine life, as Darisc stated. Shame, always so tempting to give it one last prod...
2012 911 Black Edition Cabriolet 2008 Cayman S Grey on Black - flooded, written off 1977 930 Turbo Carrera Black on Red #411 1987 951 Black on Black - sold to make room for the 930 1972 911 2.7 - I regret selling her every single day.... |
Even with a carbed car with an electric fuel pump a blip for gas for the next start is not necessary before shutting down. Why would would one want to wash down their cylinders with raw gas by bliping the throttle before shutting off the engine. I have always let the idle stabalize and let it gently shut off.
It was 28 the other morning and a few pumps before cranking she fired right up. Takes some throttle action to get the revs to 2k, let it run there for minute or less. When taking off there are a few pops after a 1/4 mile the engine is running fine and pulls great. Oil is obvioulsy not hot so that is the only thing that limits my application of throttle in the mornings. 70T Webers Last edited by gigem75; 01-04-2008 at 07:24 PM.. |
Its a bad idea on every count as that leaves unburnt fuel in the cylinders and contributes to washdown and thats detrimental to piston, ring & cylinder life.
That practice is good for your mechanic's financial well-being, but bad for your pocketbook.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
Eh, does the same apply for Motronic? My dad had that habit and transferred it to me. It's been done to this engine for 24 years.
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Seems like I read somewhere that with a sump system you are actually better off letting it idle for 20-30 seconds prior to shutdown.
madmmac AKA Mitch 1984 Factory Turbo Look 2006 4Runner 1998 TRD Supercharged 4Runner (Sleeper) |
Author of "101 Projects"
I hardly think that revving the throttle before you turn it off would cause any damage...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Registered Usurper
Let it idle for about 30 seconds while you buckle up, check your gages and mirror. Drive off and use VERY LIGHT throttle (here's the part that threw me until it was explained in very logical terms by the likes of Randy Webb, Pete Zimmerman, Steve Weiner and a few others whose knowledge runs deep): Keep the revs between 3000 + 4000 rpm until the temp is well on its way up. Again, it's extremely important to do this using a VERY LIGHT throttle foot because asking a cold engine to deliver a lot of power is even more damaging to the engine than lugging it (which you are doing, to an extent, if you ask it to pull when cold below 3000 rpm). There's an extensive thread about this on Rennlist. There will be those who say Poppy Cock! Read the thread, consider all the sources, and I'll bet you won't. Cheers David
'82 SC RoW coupe |
It's okay, normal and proper to quickly rev the up and down a bit when trying to start up from cold - helps to get the fuel flowing in the carbs and MFI. For fuel injected engines with cold start - no need to touch the gas. For fuel injected engines with a hand throttle - pull it until the engine idles at about 2000 or so and let it warm up from there. It's also okay to drive with the hand trottle engaged until the car is warmed up, but this does put additional wear on your transmission syncrhos.
-Wayne
Detached Member
I've heard the same discussion for 35+ years. You rev the engine and shut down, you've burned the fuel in the cylinder. You crank the engine, and you have raw gas on the cylinder walls? After its been sitting overnight? Maybe in one cylinder that the intake and exhaust valves are completely closed, otherwise, I don't think so. Just how much oil do you think that gasoline is washing off the cylinder walls, and where would the oil go? Answer, sitting on top of the top compression ring!
Posted later, gotta agree with David, my old and now gone Aston Martin DB4 burned a quart of oil every 30-40 miles (I'm talking a lot of smoke) and when I pulled it apart, 5 of the 6 oil scraper rings and several other rings were literally broken in two. Cause, the previous owner would fire it up in sub-zero temps and roar off.
Hugh Last edited by Hugh R; 01-04-2008 at 07:52 PM.. |
Where in God's green earth did the PO live? Did this Aston have studded tires or a plow on front of it?
1982 SC...Guards Red + Linen |
There's this TV show named "victory be design" hosted by Alain de Cadenet, if you've never seen it, you have to, it's awesome. Anyways, I noticed every time he shuts down one of the cars he's just driven, he revs it up, then shuts it off while it's revved. This guy is a very respected ex-racer, and on the show he drives some of the rarest cars in the world. I've wondered for a while if this somehow benefits the motor, and this would line up with the idea of burning up the remainder of the gasses in the cylinders.
- Everything's easier once you get started. - '95 993 C2 '73 911 Targa '88 BMW M3 '84 Mercedes 190e 2.3 16v |
Trotskyite
As for start up, I noticed on my car when I start it when it's really cold (-15C) that I have to give it gas right away after start up to keep the RPMs up until the few misfires work there way out, it only takes about 15 seconds. It really does not sound happy idling at those temperatures right away. |
Registered Usurper
'82 SC RoW coupe |
Trotskyite
Evolved
Quote: "To be honest, it isn't a showy kind of revving, it seems pretty purposeful. Just a quick blip and kill. Is Alain a Pelican? Alain, we need an explanation!"
________________________ I ain't him! ![]() But, this is a 'urban legend.' Stop the car, apply the park brake, shut off ignition. Done.
Don't fear the reaper. |
