Randy Webb's Avatar
wire on oil breather cap
What does the wire/sensor on the oil breather cap do? It's on the newer engines (i.e. a 1986 3.2L).
Old 08-01-2004, 10:54 PM
Friend of Warren
I have never seen a wire/sensor on a 3.2 oil breather cap.
Kurt V
Old 08-02-2004, 06:12 AM
I don't have one on my 85 either. Are you talkin about the smaller vent hose off the oil filler neck ?????
---Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 08-02-2004, 06:41 AM
My Sc engine has one on it and it coneects into the CIS harness. I have also seen it on a friends carrera
Ben
Old 08-02-2004, 07:01 AM
Temp Switch On Breather
It's a temp switch for the engine compartment blower.
1987 Carrera Targa
Old 08-02-2004, 07:53 AM
Friend of Warren
Re: Temp Switch On Breather
Ah you may be right. I was confused by the terminology. When he said "oil breather cap" I assumed he meant "oil fill cap." But of course he could have meant "oil breather housing" which does contain the temperature probe for the blower fan in the engine compartment.
Kurt V
Old 08-02-2004, 08:02 AM
I was similarly mistaken by the original description...good catch !
--Wil
Wil Ferch
Old 08-02-2004, 09:00 AM
Randy Webb's Avatar
Huh - well, it's the cap on top of the housing.... anyway I don't need it in my install - I don't have a blower fan. There must be some way to extract some ueful information from it tho... maybe I'll connect it to my data logger some day.
Thanks, and sorry for any confusion.
Old 08-02-2004, 08:20 PM
Does anyone know the part number for this switch? Specifically I'm looking for the part number for the switch on an '86 3.2 engine.
Thanks!
Old 01-06-2008, 06:02 AM
DUK DUK is offline
DUK's Avatar
http://www.pelicanparts.com/cgi-bin/PartsLookup/search.cgi?command=show_page&Catalog_Name=911_USA_84_86_KATALOG&Illustration=101-05&Line_Item=34
75 911 Indian Red- RUFWAN2B 2000 Boxster
2000 & 2007 Dobies
www.stahlwerks.com Cages and preparation for your Porsche
“People who never make mistakes must get tired of doing nothing”
Bill : The origin of the orgy of Porsche
Old 01-06-2008, 07:20 AM
Thanks Duke!
Next question - does anyone know if I can use a pre-'80 breather cover on a 3.2 engine?
I'm backdating the heat on an '86 engine and have deleted the engine heater fan. I think the heater fan switch on the breather cover is leaking and instead of replacing the switch I'm thinking about backdating the breather cover and eliminating the switch.
Since the breather cover gasket is the same for '65 - '89 I'm pretty sure I can backdate the cover.
Old 01-06-2008, 12:42 PM
Walt Fricke's Avatar
They all interchange, at least through the end of the 3.2 engines. Same 4 6mm studs, same gasket. Same tiny weeping/dirty spot I can't seem to get rid of.
Walt
Old 01-06-2008, 02:27 PM
