Accumulator purpose
Am I correct in presuming that the CIS Accumulator is only used/necessary for engine starting fuel pressure and that it has no other purpose?
Input appreciated. Thanks - EPS - Tucson
AMG V8 SL55 Mercedes, 993 C2, 86' Carrera 3.6 hot rod, Purple 1998 993 that didn't make the cut, 3 very old 930s, A/Fuel Dragster CH3NO2 (R.I.P.), Blown Alcohol TAD, AA/AA, 360 Maxim wingless, Cummins Turbo Diesel. Amateur Welder, Painter and sculptor sort of. - |
Senior Member
I have heard it also helps to muffle pulses in the system fuel system. It protects other components from spikes in fuel pressure, etc.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
CIS Fuel Accumulator....
According to Bosch Technical Bulletin:
Fuel Accumulator "The fuel accumulator maintains the pressure in the fuel system for a certain time after the engine has been switched off. When the engine is running it serves to deaden the noise of the electric fuel pump". |
