Engine Cradle used during engine removal
I looked over many many posts, I did some searches but I can't find a good picture of the wooden cradles people have used, without the engine sitting on it.
Can you post some pictures of your empty engine cradle? Where do you touch the engine, where do you center the jack under it? Did you used a ATV jack? How'd it work? I.e. would you use it again? Thank you.
Mike '82 911SC, SSI, 22/29 tbars, 22F/22R Adj swaybars, Bilstein Sport, Elephant polybronze & monoballs, Cambermeister bar, turbo tierods, Carrera oil cooler, front brake cooling ducts, Sparco Sprint 5 & Recaro SRD PAX seat, Teamtech harness, DAS Sport rollbar. |
Autobahn Garage
I use a funiture dolly, you can pick one up @ Home Depot or a harware store for under $25.00. All it is a a frame with caster on all four corners, you could make one out of some 2x4's. I just sit the engine on it with the heat exchangers resting on the frame work of the dolly
T Tanner 76, 911s w/ Webers 76, 914/4 57, Speedster |
I use the adapter that fits into my floor jack, I think Pelican sells it. Perfectly balances and engine and transmission. It has been lent out a few times too and those who use it love it.
cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Autobahn Garage
Ditto on the adapter, I have them for the 911,s and the 914/4
