-   -   Can someone tell me what ac condensor I need (http://forums.pelicanparts.com/porsche-911-technical-forum/386164-can-someone-tell-me-what-ac-condensor-i-need.html)
fastbacker 01-07-2008 08:43 PM
The car's a 88 930. Does anyone know which other 911 compressors are compatible with this ride. I'm also wondering what else I need - bracket and/or hardware. Thank you kindly.
http://forums.pelicanparts.com/uploa...1199767427.jpg
Barrpete 01-08-2008 06:36 AM
The original was probably a Nippondenso - don't remember the number offhand - but there should also be a plate that bolts to that bracket with jack screw on the RH side to tighten the belt. You could also get a Sanden 507 compressor and adapter plate from Rennaire. Pelican sells them.
When my OE Nippon seal went I replaced it with a Sanden, it's cheaper and works just fine.
