The car's a 88 930. Does anyone know which other 911 compressors are compatible with this ride. I'm also wondering what else I need - bracket and/or hardware. Thank you kindly.
The original was probably a Nippondenso - don't remember the number offhand - but there should also be a plate that bolts to that bracket with jack screw on the RH side to tighten the belt. You could also get a Sanden 507 compressor and adapter plate from Rennaire. Pelican sells them.
When my OE Nippon seal went I replaced it with a Sanden, it's cheaper and works just fine.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
