-   -   Trans swap problems..help!! (http://forums.pelicanparts.com/porsche-911-technical-forum/38634-trans-swap-problems-help.html)
Tlook 03-26-2001 08:00 AM
Guys, I've ran into a few snags leaving me puzzled--
When did the 915 change clutch cable style, and why. --Helper spring??--
My 911 had a 73 915 in it, and I neglected to think about swapping the cable out to different style--Nor do I have the bracket that holds the cable to the trans.
Any help is much appreciated......S in Va
john walker's workshop 03-26-2001 08:19 AM
what year body,and what year trans did you put in it? need more info.
Tlook 03-26-2001 11:20 AM
71 911e---with 78 915
EdRogers 03-26-2001 11:26 AM
I'm doing the same thing... I've heard that you can just take the clutch linkage off of your early 915, and add it to the later 915, if you want. I had the option of either when I bought my 915, and I went for the later, since porsche tends to make changes for good reasons. I was told that all I need is a later cable. The side plate was left off of mine when I bought it. That is the reason I am waiting also.
Tlook 03-26-2001 11:41 AM
Damn! Someone with the same pains kinda makes the pain a little more bearable...I do want to drive this sucker bad though.....
john walker's workshop 03-26-2001 01:37 PM
just use the release arm and vertical shaftfrom the 73 trans.
