Interior dust, something is disintegrating
There's lots of dust building up on the interior on long drives. About the size of salt. More brown then gray or white. Not course at all. Might be blowing in from heater vents. Thought I'd check with you guys to see what might be falling apart.
Jeff
87 Carrera Cab GP White
01 740i Sport
03 Honda Odyssey
Old 01-10-2008, 06:58 PM
Not COARSE?, you mean? Fine? Like table salt...
Check the under seats, sometimes the foam disintegrates and you get powder-like particles.
Old 01-10-2008, 07:24 PM
billwagnon's Avatar
I think it is the foam from the visors.
Old 01-10-2008, 08:35 PM
I don't know much about '87s, but with my '71, I believe it is the foam above the headliner. The original owner only drove my car 4,000 miles in 30 years (total mileage of 52,000), and everything was DRY. It was so bad that I couldn't drive with the windows down on the highway - always fun in the summer - because small, brown, SHARP particles would come down, and never fail to get in my eyes.
I've since put 3,000 miles on the car, and it's better - I can now drive with the windows open - but I still have to occasionally wipe down the dash, door panel tops, etc. I've learned to live with it, accepting the fact that my car has dandruff.
My 1.5 cents.
John
Old 01-11-2008, 07:36 AM
gigem75's Avatar
Same here on a 70T. Especially at speed (weatherstripping is 38 years old) it sometimes snows in the car. Thanks for the info about the headliner. It seems to be comming from there and the passenger visor.
Old 01-11-2008, 07:47 AM
Thanks guys. The dust is not coarse. If you rub some flakes between your fingers they immediately turn to powder. I will check my visors and read up on the fresh air butterfly valve seals. My 87 is a Cab so no headliner.
Thanks,
Jeff
01 740i Sport
03 Honda Odyssey
Old 01-11-2008, 08:36 AM
Noel's Avatar
My 1.5 cents.
John
After reading this, I had a very funny image of you driving around town with swimming goggles on to keep the dust our of your eyes.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 01-11-2008, 09:02 AM
+1 on dust from seat foam disentegrating...and finding its way around the floor.
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 01-11-2008, 11:16 AM
Matt
mhoffman's Avatar
how is the firewall pad? it disintegrates and is over your heat control valves which are open if the heat is off...
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 01-11-2008, 12:57 PM
Hi Matt,
I removed the sound pad about 1000 miles ago. It was seriously deteriorating.
When I removed the pad, I placed a sheet over the engine and vacuumed as best I could. I would think that most of the residue has long since dissapeared
but I suppose some could still be lodged in the heater ducts. Won't have much chance to investigate until tomorrow.
Jeff
01 740i Sport
03 Honda Odyssey
Old 01-11-2008, 03:18 PM
eR1c's Avatar
that sound pad stuff is a pain in the butt. I would find a small amount on top my air filter housing after every drive.
-I too finally took the shop vac to it and got rid of all of it. Also replaced my air filter as it looks like there is a build up of that sound material all over the air filter. -what a mess that stuff is (was).
1977 930 Turbo
Old 01-11-2008, 03:29 PM
I think its the paper heater hoses. I remember my old ones use to blow into the cabin from time to time..sometimes as paper does, a glow! Mostly, it was the flakes of ash.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 01-11-2008, 03:54 PM
