The Puff.
Crank case screw plug seal missing?
For some reason the PO's mechanic had not put a seal on the crankcases screw plug (he used JiffyLube sometimes
). The damn things was torqued so tight that I had to use my hydraulic jack + a socket wrench to get it off... way more than 51 ft-lbs. Could this have been what was causing my oil leak?
The Puff.
(or oil drain plug if you prefer).
yes
72 Carrera RS replica, Spec 911 racer |
The Puff.
Awesome. I thought it was something serious when my oil kept disappearing.
