Smile Rocker shaft nut size 911
I need to get the correct hex head size to loosen the nuts on both ends of the rocker shaft on a 81 911 Thanks Frank
Old 01-08-2008, 06:53 PM
Frank, the large side is 8mm and the other is 5mm
Old 01-08-2008, 09:02 PM
Also, the 8mm allen wrench needs to be short or cut shorter on the business end to fit into the recess on the front and rearmost cylinders.
A 1/4" drive 5mm hex socket on 1/4 " ratchet or breaker bar works best on those. If you can't find one of those easily you can cut a short piece off of a 5mm allen head wrench and slide it, or glue it, or braze it into a 5mm 1/4" drive socket and use that.
Old 01-09-2008, 11:08 AM
Nut size
Hey Great ...Thanks so much for the info,..I tried every size and could'nt seem to get a good fit...now I can get back on the road !!!! Frank
Old 01-14-2008, 10:59 AM
