-   -   Whats the difference between the 911 and 912? (http://forums.pelicanparts.com/porsche-911-technical-forum/38681-whats-difference-between-911-912-a.html)
72porsche914 03-23-2001 08:49 PM
Im new to these (bought a 67 912 yesterday) and will be restoring the car. I know about the motor differences. I want to know about the interior/trim/ body differences. Help is greatly appreciated.
campbellcj 03-23-2001 09:10 PM
You may want to pick up the "Guide to Restoration and Authenticity" book(s) by Dr. Brett Johnson. I think they do a pretty good job of explaining the details and differences of various models & years.
Doug Zielke 03-23-2001 09:55 PM
About a 100 horsepower.
Doug
'81 SC Coupe (aka: "Blue Bomber")
Canada West Region PCA
members.home.net/zielke/911SC.htm
dave cardone 03-23-2001 10:11 PM
we 912 owners make up in courage what 911 owners douse with horsepower and commonality (or that's what we tell ourselves!)
Dave
josh912 03-24-2001 08:21 PM
About 100 horsepower! I don't think so! Try about 20 horsepower between the original 911 and 912 (110 to 90). And with the 912 you get better handling, so ha!
Joshua Harrison
1968 912 Coupe
rstoll 03-24-2001 09:43 PM
Ah, courage. Courage is good.
Robert Stoll
83 SC
83 944
Wolfman 03-25-2001 01:52 AM
Just had a quick look through "Porsche Buyers Guide" by Batchelor and Leffingwell and here are some of the differences:
912 uses the 1582cc flat four from the 356SC. It was slighly detuned form the SC's 95HP to 90 due to larger air filters and 911 look alike exhausts.
The instrument panel on the early cars had only 3 dials, speedo,tachometer and combined fuel and temp gauges which were similar to the 356SC.In 65 Webasto gasoline heaters were available and in 66 the track was widened.In 67 the 5 dial dash became standard and safety door locks were added. Interior carpeting was upgraded and new engine mounts were fitted. In 69 the wheelbase was lengthened.
It also states that engine maintenance should be less that that of a 911 but that some mechanics recommend replacing the 912 engine if major repairs are needed. The 912 crankshaft is viewed as the weak link in the engine.
Hope this helps
Cheers
Ralph
Doug Zielke 03-25-2001 09:27 AM
While owners of the "better handling" 912's contemplate their spindly crankshafts, they should view Harry Pellows excellent 356/912 website at:
http://www.hcpresearch.com/
Mr.Pellow is the legendary "Maestro", Flat-4 engine re-builder to the Stars (Jerry Seinfeld, among others).
Doug
ScotMcLean 03-25-2001 09:59 AM
While the "spindly crankshafts" may be an issue, the 912 is fun car with good parts availability overall. Check out the seatbelts and upgrade to three point if needed.
My first was 67 (in 1994) and I later switched to a 69. I found getting parts for the 69 was easier, and like the long wheel base. The long hood is classic, and the chrome gives it a distinctly early look.
The back seats are small, but my back seats old toddler seats for my four year old twins with no problem. It is a solid around the town car and the maintenance, with the relatively simple engine, etc. is handy. I found an AZ parts car like yours for next to nothing and it serves as an organ donor w/ spare engine/tranny, etc. Overall the cost for daily driving is very comparable to a newer Honda and is certainly more fun.
If you get to race on the weekends, with some planning you can plug in a larger engine, and really take the frame in a number of different directions - see Clay's web page for example.
Of course, if you have the means, a 78-83 SC is nice.
Backroads in AZ at 85 (w/o twins) isn't terribly fast but the roadfeel is 110 http://www.pelicanparts.com/ultimate/smile.gif
tchanson 03-25-2001 11:37 AM
You may also want to look at: http://www.912registry.org/home.htm
Tim
hoff944 03-25-2001 12:15 PM
I know a stock 912 can do 120mph. I can vouch for that. I have the photo to prove it. Actually its a hair over 120mph and its right at redline.
Jim T 03-25-2001 01:08 PM
-1?
Jim T 03-25-2001 01:09 PM
How can a photo prove that a 912 is doing 120? Is it a photo of the readout on a radar gun?
Because you surely aren't referring to a pic of the speedo, which is really just for entertainment purposes at high speeds, and has no relation to the speed of the car!
JackOlsen 03-25-2001 01:50 PM
A snapshot would have to show the tach. The true speed could then be confirmed by the gearing of the transaxle and the specific rear tire size.
dave cardone 03-25-2001 01:53 PM
Or, how big the bug-splatter is if you knew the size and density of the bug in question prior to impact?
hoff944 03-25-2001 04:02 PM
Actually its got a the tach in the picture too. Its a little over 6,000RPM in fifth gear.
Doug Zielke 03-25-2001 04:03 PM
A 120 mph 912? The stuff dreams are made of.
Doug
Mrdi 03-25-2001 04:24 PM
4 rungs
josh912 03-25-2001 04:30 PM
Not to ruin your day Hoff944, but what size tires do you have on the 912. My 912 can go up and beyond 6000 rpm in 5th gear but it ain't going 120 mph! But then again I haven't tried for 120 yet! http://www.pelicanparts.com/ultimate/smile.gif
Joshua Harrison
1968 912 Coupe
hoff944 03-25-2001 06:15 PM
The wheels were the stock 4.5 x 15 with 165HR tires at the time of the photo. I wish I could get this photo scanned just to show you nevertheless. Whether we were really going 120mph or not, its still a cool pic.
[This message has been edited by hoff944 (edited 03-26-2001).]
