Hbrand
hbrand's Avatar
Oil does not drain back into engine.
I have an original 1974 Porsche 911. The car is parked for days, the oil stays in the oil tank and does not drain into the engine.
There is no blockage at the big oil hoses and metal line.
Is that normal??
thanks, Harold
Cheers
1982 Porsche 911SC Euro
1969 Mercedes 280SL
1956 Austin Healey 3x
Old 01-16-2008, 06:27 AM
Yes. On a dry sump system almost all of it will be in the tank.
A quart or so will stay in the engine. Also a bit in the lines an oil cooler.
Old 01-16-2008, 07:51 AM
loose engines with extra clearance (wear) in the oil pump and crankshaft bearings transfer oil faster than tight engines do.
206 637 4071
Old 01-16-2008, 08:58 AM
Hbrand
hbrand's Avatar
Thanks for the Info. This engine pulls a s much as the 2.8 RS I had installed before.
Thanks Harold
Cheers
1969 Mercedes 280SL
Old 01-16-2008, 01:44 PM
