Hopelessly Addicted
Porschephanatic's Avatar
Unhappy erratic speedometer
I've searched this forum for erratic speedometer behavior, but didn't find anything like this. The one on my '81 SC works without fluctuating, as well as the odometer, up to 18 mph or so, then both quit at the same time. Anyone else experience this? Thank you.
'81 SC Targa
'86 944
'49 Ford F-3
'13 Yamaha FZ-1 (Adrenaline Machine)
Old 06-24-2017, 11:23 AM
proporsche's Avatar
hi i do not know why 18mph but have a look at the engine compartment plug on left.possibly loose connections...
Ivan
here
https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcSdcSk6RepfpdUhKnU4FVqEE7WhSys2f LdbmH4eNZZ6dKz4g8ygww
Old 06-24-2017, 12:20 PM
Mine used to work perfectly up until about 60mph then start misbehaving. A new speed sensor sorted that out - it was brittle and falling apart with lots of white powdery corrosion behind it.
Old 06-24-2017, 12:35 PM
Hopelessly Addicted
Thumbs up Thank You
I'll check both.
'81 SC Targa
'86 944
'49 Ford F-3
Old 06-24-2017, 03:16 PM
Hopelessly Addicted
Question Update
I ordered a new sensor from Pelican since it was 36 years old anyway and installed it, after I checked all connections.No corrosion anywhere, and now indicates mileage and speed up to 20 mph, then needle drops to 0 and odometer quits. Send speedo unit to Palo Alto?
'81 SC Targa
'86 944
'49 Ford F-3
Old 07-02-2017, 02:43 PM
Before sending the speedo of, jack up the rear of the car to check you are getting 8 pulse per wheel revolution. Connect a VOM at the connector in the tunnel to verify that the reed switch is switching 8 times per wheel revolution. If you are getting 8 pulses, then there is a problem with the speedometer's pull up circuit that converts the reed switch action to 12 vdc pulses. If you are not getting 8 pulses, then one or more magnets on the disk inside the transmission have dislodged causing the pulse rate to be unstable.
-Dennis
1977 930 Slant, MS3 EFI, Carrera intake, Twin plug, Powerhaus headers, Magnaflow muffler, Garretson intercooler, GTX3071R
Old 07-03-2017, 08:49 AM
Hopelessly Addicted
Thank you
Got 8 pulses
'81 SC Targa
'86 944
'49 Ford F-3
Old 07-03-2017, 04:47 PM
Eng-o-neer
Tremelune's Avatar
My money is on a loose connection in the transmission tunnel by the shift coupler:
Speed sensor, bouncy gauge, sketchy wiring...
Old 07-04-2017, 05:35 AM
Hopelessly Addicted
Post Update
I checked all connections, then sent my speedometer to a VDO authorized repair shop here in PA.
They called today, but I couldn't answer the call at that time. The voicemail informed me that what I sent them could not be repaired, but I could buy from them a reconditioned unit for $675, including shipping. I imagine they will ship my "irreparable" unit back.
I'll call them tomorrow to get more details. (core, condition, warranty, etc.)
Does this sound reasonable?
Thank you for your responses.
'81 SC Targa
'86 944
'49 Ford F-3
Old 07-18-2017, 03:15 PM
