-   -   Ignition problem (http://forums.pelicanparts.com/porsche-911-technical-forum/388239-ignition-problem.html)
tcarideo 01-19-2008 08:13 PM
Ignition problem
I'm wondering if anyone can help me diagnose an ignition problem. I have a 1980 911. It starts just fine, but when I turned the key today to shut down the engine, it kept running. I had to stall out the car to stop the engine, then disconnect the battery to turn off the auxiliary power. I'm assuming there's something wrong in the ignition switch (duh). What I don't know is how big a problem it might be -- something loose? A whole new assembly?
Can anyone venture a guess?
Thanks.
Tony
2002M3Drew 01-19-2008 09:01 PM
Check the plug under the dash under the steerig column (follow the wire from the back of the igition to the "plug" and make sure it is seated).
tcarideo 01-20-2008 12:52 AM
Mr. Drew,
Thanks for your response. That's potentially a much less expensive solution than I expected.
I'll try that.
Tony
