Ignition problem
I'm wondering if anyone can help me diagnose an ignition problem. I have a 1980 911. It starts just fine, but when I turned the key today to shut down the engine, it kept running. I had to stall out the car to stop the engine, then disconnect the battery to turn off the auxiliary power. I'm assuming there's something wrong in the ignition switch (duh). What I don't know is how big a problem it might be -- something loose? A whole new assembly?
Can anyone venture a guess?
Thanks.
Tony
Old 01-19-2008, 08:13 PM
2002M3Drew's Avatar
Send a message via AIM to 2002M3Drew
Check the plug under the dash under the steerig column (follow the wire from the back of the igition to the "plug" and make sure it is seated).
1983 911SC Coupe
1985 928S
1987 944 Coupe
1992 Carrera C2 Coupe
2006 Cayenne S
Old 01-19-2008, 09:01 PM
Mr. Drew,
Thanks for your response. That's potentially a much less expensive solution than I expected.
I'll try that.
Tony
Old 01-20-2008, 12:52 AM
