smk911
Guest
Posts: n/a
Question Performance chips?
Who makes the best performance chip for 3.2L Carrera's? I've heard Autothority are probably the top of the line. Do you agree?
89, 911 Carrera Cab
Old 03-31-2001, 09:05 PM
adamnitti
Guest
Posts: n/a
Post
if you do a search on 'performance chips' in past messages here i think you'll find all the info you'll need on chip comparison. i think you'll also find that most have experienced that the chips don't make THAT much of a difference in a 3.2... i could be wrong, though; i haven't tried a/b'ing one, myself.
Adam Nitti
ajnitti@mindspring.com
www.adamnitti.com
'85 911 Carrera Coupe
PCA member, Peachstate region
Old 04-01-2001, 08:06 AM
Stephan Wilkinson
Guest
Posts: n/a
Post
The only place performance chips really make a difference is with turbocharged engines, where a chip can turn up the boost and do whatever else is necessary to handle the higher horsepressure (assuming you use the right gas, etc.). Put a chip on a naturally aspirated engine and all you're doing is remapping things so that you get a little more power here at the expense of less there. If you want to do something specific like achieve maximum torque at a different point than stock, a chip is fine, but if you expect a chip to raise horsepower at all rpms, you'll be disappointed.
Stephan
Old 04-02-2001, 03:03 AM
