Battery Wiring
I removed the old alarm from my 71 911 and now need to reinstall the wiring. According to the wiring schematics there are 3 wires that come off the positive battery terminal. Does any one know if this is correct and where do they go?
gary burch 71 911 |
Air Medal or two
If they all came off the + post the order installed would not be that important
162 Assault Helicopter Co,(Vultures ) D troop 3/5 Air Cav. ( Bastard CAV) South of Saigon, U Minh Forest, Delta, and most parts in between. |
The schematics are nearly always correct. If you have them, should be easy enough to trace where the wires go. On my 73, two went to the ignition switch and one to the top fuse panel.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
I would hope that the schematics are correct. The only problem is transferring the schematic into reality.
gary burch 71 911 |
