cubby911T's Avatar
Help Identify DME chip
Guys - Upon purchasing my 3.2 motor, the PO believed that it had an aftermarket DME chip installed. I finally got around to popping open the DME box and here is what I found. Is this an aftermarket chip or a factory chip with the sticker missing? It looks like the letter "i" on the left which I would guess to mean intel, but not sure.
Matt M. -- Go Irish! 1990 964 C2 Targa
"Cheap tools and no experience has taken its toll" - J.W.
Ghosts of the Past: '77 911S Targa 3.2 Conversion, '89 Carrera Coupe, '99 Boxster, '70 911T Coupe ,'80 911SC Targa, '77.5 924
Old 08-10-2008, 09:35 AM
You are correct about the "i" - it's just the chip makers mark - intel
Old 08-10-2008, 03:12 PM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
My original stock chip had (has) as plain silver label with a 10 digit number on it. Yours looks aftermarket, I just have no idea whos it is.
You might try to PM Steve Wong (here on this board - do a search for his name). He's probably the most knowledgeable I've ever seen write on this topic.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 08-10-2008, 06:31 PM
Platinum Member
dad911's Avatar
Look around in the box for the label that fell off.
Old 08-10-2008, 07:01 PM
cubby911T's Avatar
No luck finding a sticker in the box (good idea to look though). I just sent a PM to Steve Wong asking him to take a peek. Maybe he can shed some light here. By the way, I bought one of Steve's chips for my previous car ('89 Carrera) and loved it. I'm looking to go that direction again, but I'd like to know what I'm starting with here.
Old 08-10-2008, 07:34 PM
slodave's Avatar
I just looked at my stock chip and the OEM sticker is not centered. I can see the same markings yours. I'd put a piece of tape over the round window. I have a spare SW chip, but his label covers the whole top.
I'm guessing that yours is stock.
Old 08-10-2008, 08:43 PM
scarceller's Avatar
That is a 2732A EEPROM (4K Chip) but without the label you have NO clue what is on it.
Because the Porsche original label is missing, my guess is that someone burned a new chip and installed it.
The only way to know what's on the chip would be to read the data off the chip and compare it to factory chips.
You should really try to find out what that chip is or install a known stock chip.
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 08-11-2008, 07:14 AM
cubby911T's Avatar
Sal - Steve Wong wrote me back and said pretty much the exact same thing.....that it is a copy, but he would have to analyze it to determine exactly what it is. Steve advised that I get the engine running with a known good chip before making any changes. The PO tells me that the engine ran fine with the current chip, so I will try to get it running properly "as is" before making any chip changes.
thanks guys.
Old 08-11-2008, 08:28 AM
scarceller's Avatar
thanks guys.
Matt,
I'm sure Steve mentioned this but here goes anyway:
Be very carefull of a chip of unknown origin, you don't know what was altered. For example: pushing the timing to far advance (which is often done) could lead to fuel detonation and engine damage. You also have no idea what fuel octane rating the chip was created for. If you plan to stick with this chip I advise you to use 93 octane fuel to be safe.
I agree with Steve 100% that you should consider going to a stock chip. I think Steve can burn you one for very cheap price.
One last thing: put some tape over that window on the chip if you plan to leave it exposed to light. Once these UVProms are burned they should have the glass window covered up to prevent any light from getting in.
Best of luck.
Sal
1964 356SC (SOLD)
Old 08-11-2008, 09:47 AM
