1981 911SC Targa
injector question
I have taken off my CIS intake system and noticed that where the injector lines attach to the actual injectors that he injectors spin. They are not in essence loose, but you can spin every one of them=is this normal. I suppose it is because I had a fine running engine at the time I disc. the head stud problem.
How do these inj. come out and is this something I should replace?
Frank
1981 911SC Targa
1967 Buick GS-400
Old 01-30-2008, 05:32 AM
GaryR's Avatar
Send a message via ICQ to GaryR
They are held in by a rubber O-Ring and simply pop out. I did mine following my shop's intricate instructions using special tools. "Take 2 12mm wrenches, put them between the injector and the intake and pry them against each other.. the injector will pop out".. and they did!
Gary R.
Old 01-30-2008, 06:09 AM
Tired Member
DaddyGlenn's Avatar
You should be able to twist them. There is nothing to prevent that and it is not a bad thing. However, they should be pretty snug. It can't hurt to replace the injector o-rings. It is cheap insurance against developing a leak there. I did mine a year ago. The o-rings are inexpensive and it is an easy job.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 01-30-2008, 07:18 AM
Matt
mhoffman's Avatar
if you do replace the o-rings, you might as well do the sleeves too- they get brittle with age. They are not expensive at all. Good chance to have the injectors cleaned or clean them yourself too. (That slippery slope you always hear about...)
To answer your base question though of if they should be tight, the o-ring just provides a seating surface for the injector- it is not designed to be airtight with a differential pressure. The CIS Primer has a good discussion of it. The injector is "upstream" of the combustion chamber and is only exposed to a vacuum as the intake valve is open during the fuel injection and air intake stroke, which tends to seal further the injector (the vacuum in effect "pulls" on the injector, seating it further against the o-ring and sleeve).
The neat things about these cars is that nothing was done without a purpose- it is not always obvious what the purpose is (or was), but once you figure it out it helps to make operating them and maintaining them a good deal clearer, and then being able to approach modifications more informed and intelligently.
Hope that helps...
79 SC Targa
87 m491 Targa
73 BMW 3.0 CS
73 BMW R75/5
88 BMW M6
Old 01-30-2008, 08:05 AM
Tired Member
DaddyGlenn's Avatar
Originally Posted by mhoffman View Post
{snip}...To answer your base question though of if they should be tight, the o-ring just provides a seating surface for the injector- it is not designed to be airtight with a differential pressure. The CIS Primer has a good discussion of it. The injector is "upstream" of the combustion chamber and is only exposed to a vacuum as the intake valve is open during the fuel injection and air intake stroke, which tends to seal further the injector (the vacuum in effect "pulls" on the injector, seating it further against the o-ring and sleeve). ....{snip}
Very enlightening and it makes perfect sense. Thanks.
+1 on the sleeves, too.
Glenn
Old 01-30-2008, 08:56 AM
1981 911SC Targa
Perfect, those are the answers I was looking for.....an easy and inexpensive repair!!!
1 for 23 is not too bad.
Thanks Gents
Frank
1981 911SC Targa
1967 Buick GS-400
Old 01-30-2008, 12:32 PM
